Ga door naar hoofdinhoud
Uitgebracht op 26 oktober 2018. Modellen A1984, A2105, A2105, A2106, A2108. Verkrijgbaar als GSM of CDMA / eSIM, nano-SIM of dual-SIM / 64, 128, of 256 GB / Zwart, Wit, Blauw, Geel, Koraal of Rood. (Uitgesproken "iPhone 10 R.")
468 Vragen Bekijk alle
touch keeps going after screen change
hi I have changed a screen on a iPhone XR, have used the supplier and XR screens before and never had a problem. the phone was working fine, then after 4 days the customer turned the phone off and then touch stopped working. I did a force restart and the touch works fine, once the phone is turned off the touch stops responding again. a force restart and it works fine again. everything seems fine, I also used a icopy to copy over from the original screen. cant find what I am missing? any help pls
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Obviously, you’ll want to double check your work and insure there isn’t any damage to the screen or flex. Even with the best suppliers, you will get an occasional dud screen. Try installing another screen to see if it solves the problem.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
dan morrill zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 45
