Ga door naar hoofdinhoud
Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
54 Vragen Bekijk alle
Console power diode blinks for a second, then turns off.
As in the title, when I’m trying to turn the console on (with new, top brand batteries) the power diode blinks for a moment and then goes dead. I am sure it’s not caused by loose wires, dirty battery contacts, broken circuit paths or rust, as I cleaned the device after buying it. No parts look rusty or leaking either.
I’m afraid it could be an issue with resistors, as I heard they tend to burn, but I’m not sure.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
i’m answering my own question, as i found the solution lol
turns out i just had to absolutely spam power switch for few minutes, so the contacts inside could clean a bit. and now it works perfectly fine! turns on every time. probably a little bit of IPA could also help.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Roth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 10
Altijd: 71
