Ga door naar hoofdinhoud
Jeans are comfortable, everyday pants usually made from tough yet comfortable denim.
4 Vragen Bekijk alle
How to repair holes in the crotch of my Tenpenny Pants
My Patagonia Tenpenny Pants have developed some holes/rips in the crotch. Most of my trousers do this eventually. Is there a repair I can make to get more life out of them? They're made of cotton/polyester
Thanks
Is dit een goede vraag?
Score 1
1 Opmerking
Chub rub! Also my primary failure point for all Pataguchi pants. There MUST be an easier repair than just loosing weight.
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
You can do an iron on patch:
Installing an Iron-on Patch
The zig-zag patch requires a sewing machine:
Zig-zag Patch
Patagonia Jeans Afbeelding
Handleiding
Zig-zag Patch
Moeilijkheid:
Eenvoudig
10 - 15 minutes
Jeans Afbeelding
Handleiding
Moeilijkheid:
Eenvoudig
5 - 10 minutes
Was dit antwoord nuttig?
Score 3
5 opmerkingen:
I saw those,but I wasn't sure if they would work on a non-flat bit of the clothing (the crotch is a kind of saddle shop on most clothes)
door
I've done it on elbows. I put a patch on both sides and sometimes hand stitch the corners down so they don't curl up. eBay has patches but most come in from China (I've had a set of denim patches ordered now for a couple of weeks but the shipping now says VOID). You can probably find them in the states just at a higher price.
door
Clothing starts out as a flat piece of fabric and has curved seams to fit your shape. You can smooth down the area to where it’s flat and add a patch. You’ll follow the curved seam to keep the shape. If you are hand sewing use a back stitch which is strong and won’t loosen. For a source of patches try your local fabric stores. You don’t have to use a precut patch, you can cut your own from new fabric or my favorite, old pants ( which are already softened from wear). Denim will fray on a cut edge so just put the patch on the inside if that’s not what you like. or enjoy an edgy look.
I love that ifixit supports repair solutions!
door
I’d like to know how to make the crotch longer as it is short counting from the waist and feels uncomfortable to wear
door
Sorry, I believe the correct word is hanger not crotch. The pieces that goes from the waist to the crotch.
door
Voeg je antwoord toe
Matt Freake zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 25
Altijd: 2,508
