Ga door naar hoofdinhoud
A2116 / 2019 / 3.6 GHz quad-core i3, 3.0 GHz 6-core i5, or 3.2 GHz 6-core i7 processor. Released March 19, 2019.
Add an PCIe SSD alongside the existing HDD
Hello everyone, I have a an iMac 21,5 4K 2009 buy last summer with 1TB HDD and 8gb RAM (the entry level) I want upgrade my RAM and my HDD my question is possible to add alongside the existing HDD an SSD PCIe or the slot is missing?
Thanks.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
As expressed here: 21.5” iMac 21.5 (4K, 2019)
“It has a Serial ATA (6 Gb/s) connector for a 2.5" hard drive. If configured with a "Fusion" Drive or an SSD at the initial time of system purchase, it also has a PCIe connector, but this connector is not present if the system only was configured with a hard drive.”
Sadly, Apple did you in. You could upgrade the SATA drive to a SSD. Frankly, I recommend going with an external Thunderbolt drive. To get the best performance set it up as your boot drive! Hint! A RAID’ed SSD is faster than the internal PCIe/NVMe drive.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the info
door
@Fbook what was your conclusion? Did you have a PCIe slot?
Voeg je antwoord toe
fbook zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 322
