Ga door naar hoofdinhoud
A1418 / EMC 3069 / 2017 / 3.0 GHz quad-core i5, 3.4 GHz quad-core i5 or 3.6 GHz quad-core i7 Processor. Released June 8, 2017.
176 Vragen Bekijk alle
Fitting second hard drive
I have a 21.5” 2017 iMac which has an Apple blade SSD (SM0512L) fitted.
I have removed the screen from the iMac and the 2.5” drive is totally empty.
I was thinking of mounting a 2.5” SATA SSD in this drive bay, but I am not sure if the SATA connector is in place.
Please confirm whether the SATA connector would normally be in place if a blade SSD has been fitted and if not whether it is possible to order the SATA connector nad mount a 2.5” drive as a second drive (leaving the blade drive as the boot drive)?
If the SATA cable needs to be connected, is it necessary to remove the logic board in order to plug in the cable>
Thanks for any help that you can provide.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The logic board connector is in place you’ll need to install the combo cable (SATA & Power).
iMac 21.5" (Late 2013-2017) SATA Cable
Yes, you’ll need to loosen the board to gain enough room to install the cable
iMac 21.5" (Late 2013-2017) SATA Cable Afbeelding
Product
$12.99
Was dit antwoord nuttig?
Voeg je antwoord toe
Darrell Haslam zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 83
