Ga door naar hoofdinhoud
Want to connect external monitor
I made a newbie mistake... putting the screws back into the side of my computer where the ethernet port, firewire and the connection I use for hooking to my large monitor is, I inadvertently put the screw into the hole beside the monitor plug in... Instead of the screws hole.
I have tried everything to get the screw out, from magnets, to silly putty, etc... I cannot find any directions for taking this part out and replacing it or even what to call the part.
I know it's not essential to hooking up my monitor, but I'd like it to be right. Any suggestions? If I need to simply replace the plug in for the monitor, I will, but don't know how or what to order.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I've had a couple of these come in that way and had to use a screw extractor to get them out. The port is part of the logic board and can't be replaced. Here's what I use: Precision Screw Extractor Set
Four different sized extractor tools to help remove fasteners or screws with stripped heads. Driver head is claw shaped for maximum grip. Sizes range from 1.1mm to 2.0mm. Afbeelding
Product
$24.99
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Donna Parrish zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 6
Altijd: 1,249
