Ga door naar hoofdinhoud
The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
Which of the three Mainboard-Connectors is for the Touch-Sensor?
After disassembling my 8 gig 1st Gen iPhone in order to replace the broken glass and digitizer I found my Touch-Sensor not working anymore.
So I redid the whole procedure and it worked without a glitch, for about 3 hours...
Since everything besides the touch-recognition works I think it might be a faulty connection from the digitzier to the logicboard.
Does anybody know which one of the mainboard-connectors is responsible for what task? I named the connectors as follows ;)
  • the one on the side of dock-connector (with the black clamp)
  • the really annoying small one on the camera-side
  • the bigger one on the side of the camera.
Thank you very much for your help!
Is dit een goede vraag?
Score 5
1 Opmerking
+1 for a well written question
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I Believe that in this photo, it is the cable on the top-right:
http://s1.guide-images.ifixit.com/igi/DF...
Was dit antwoord nuttig?
Score 3
So, when u open the iphone, to take the touchscreen out, you gotta disconect one cable, by sliding it out, then another by pushing and another one by pushing too... your problem is in the number two! i fixed my iphone and in the end, the touchscreen wasn´t responding... the conector number one was good, the number two was loose and the number three was ok... so i pushed the number two conector and it made a "click" sound.... then it came back to work...
Voeg je antwoord toe
tokyo2ooo zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 11,807
