Ga door naar hoofdinhoud
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Vragen Bekijk alle
I’m from India I recently Purchased US version series 4 Apple Watch
I’m from India I recently purchased  a US version series 4 Apple Watch with a cracked display.
I had a new display assembly put on, but the technician didn’t transfer the NFC chip from old display assembly.
My watch is working now but in future if I unpair my watch and pair it again or am I stuck? Because I don’t have old screen.
In India we don’t have Apple Pay support yet so I don’t need it.
But watch Is US version even I want to confirm that if unpair it will pair or not
Kindly help me
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
The NFC module only deals with payments it won’t effect your usage. Unpairing and re-pairing to a new iPhone won’t be an issue. But of course if and when Apple Pay services are introduced in India your watch won’t work.
Update (03/11/2020)
You’ll need a PC or Mac system which you can setup to monitor your WiFi and Bluetooth connections. Then you should be able to see what is happing when you try to pair your watch to your iPhone.
As an example here is the needed apps for MacOS:
Update
If you reset your watch you’ll loose access to it! If you have someone else’s display assembly. A new assembly won’t have this issue.
Was dit antwoord nuttig?
13 opmerkingen:
I unpair my watch it won’t repairing
While pairing automatically screen shows unpairing Apple Watch on my Watch app
What I do
I don’t have old screen now
door
Then your real issue is the Bluetooth and Wifi connections between the watch and your iPhone.
door
I tried with several iPhones
Can’t activating my watch
door
Did you check your Bluetooth & WiFi services?
door
Yes , I tried over 40 times
What’s the solution
Kindly help me
door
8 commentaren meer tonen
Hello Dan !
Sorry for giving you trouble
Please advice lastly if issue happened with WiFi & Bluetooth how to resolve that
Kindly advice
Thanks
12 opmerkingen:
You will need a new SIP unit if both have failed, Otherwise the antenna connection are damaged.
door
Can you send the antenna pic &
where is located in Apple Watch &
Again it cause any pairing issues ?
door
Replacing the SIP is only > IF < the Bluetooth and WiFi were not working.
Before you reset your watch it was working with your iPhone correct?
As I said as long as you don't do that you'll be OK. Now your failure is due because your NFC chip not being ID'd to your user ID the watch is expecting as you reset your phone.
You would need the correct SIP unit for your phone. Each series has different SIP units. As Apple doesn't sell parts directly you can't buy the part you would need to find another broken watch to transfer the part from. That would fi the antenna issue if that was your problem.
I think we are going in circles here ;-{ I think its time to get a brand new watch directly from Apple (never used)
door
Yes, before reset it was working but I observed it was long time to booting up average 5 to 8 minutes
At first day when I changed screen it was stuck on Apple logo for 1 hour
That time only I had doubt it has damaged any component
In that reason only I erased Watch
And also here in my country no Apple Pay
Still it caused with NFC
door
Sorry ;-{ Time for a new Apple Watch
door
7 commentaren meer tonen
Voeg je antwoord toe
feroz_khan77874 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 214
