Ga door naar hoofdinhoud
A Vent-Axia brand mechanical ventilation heat recovery, or MVHR, it is an energy recovery ventilation system.
3 Vragen Bekijk alle
Fan is oscillating - display dead
Ventilation is going into boost modus and going back to standard, making lots of noise.
I don’t seem to be able to get in the menu, display shows a half bar.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hi,
It sounds like the logic board has failed. The spinning up could be the humidity sensor or it could be the faulty logic boards.
Some systems have a wired controller if this is the issue then you can check the screen on the unit itself. In this case a new remote controller can be added. It would be interesting to know what the issue was as I appreciate you asked this question a while ago.
Hope this helps,
Tom.
Was dit antwoord nuttig?
Voeg je antwoord toe
Wim Godefroid zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 236
