Ga door naar hoofdinhoud
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 Vragen Bekijk alle
There is no power in the machine
I have a Maytag bravos. There is no power in the machine even though there is power in the plug, so it is a machine problem. I have tried the three second reset it resets nothing. The top lid is locked, stuff is inside, and what do I do?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Cause 1
User Control and Display Board
To determine if the user control and display board is defective, try pressing the buttons on the control panel. If some of the buttons work, but others do not work, the control and display board might need to be replaced. Additionally, if the display is not working, check the power to the user control and display board. If the user control and display board has power, but it isn’t working, replace it.
Cause 2
Timer
The timer is frequently misdiagnosed—before replacing the timer, first check all of the more commonly defective parts. To determine if the timer is defective, consult your washer’s wiring diagram and use a multimeter to test the timer for continuity.
Cause 3
Line Fuse
The line fuse blows if the washer circuits are overloaded. If the line fuse blows, the washer won’t start. To determine if the line fuse is at fault, use a multimeter to test it for continuity. If the fuse does not have continuity, replace it. In addition, you should investigate and resolve the problem that caused the fuse to blow. Check for shorted out components such as the wires, motor, or drain pump. If you don’t resolve the underlying issue, the new fuse will blow too.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
My Bravo is literally putting pieces of dirt on my clothes. Why?
door
mrsizz Cleaning a Washing Machine
Fill the empty washer with hot water, as if you’re doing a large load of laundry.
Add the quart of bleach, and let the full machine run for one minute to mix up the bleach with the water. Open the top of the machine and let it sit, all bleach-y and full, for an hour.
At the end of the hour, shut the cover and let the machine run a complete cycle. (The water will drain out all the bleach, so it won’t have a chance to mix with the vinegar.)
When it’s done, start again. This time, when you fill the washer with hot water, add the quart of white vinegar to the water and down the bleach channel.
Let the machine run for a minute to agitate the water and vinegar. After that minute, open the top of the machine and again, let the hot water sit in the basin for an hour before you let the cycle complete.
After cleaning the basin, spray the gaskets, dispensers and exterior of the machine with a solution of equal parts vinegar and water. Wipe everything down with a clean cloth.
door
Voeg je antwoord toe
Mike H zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 3,004
