Ga door naar hoofdinhoud
Mid 2012 model, A1278 / 2.5 GHz i5 or 2.9 GHz i7 processor.
1624 Vragen Bekijk alle
Can I swap my old hard drive into my new machine?
My 2011 MBP suffered from a dead short by the LVDS connector, which burned the board :-(. The problem is the cost of repair the damage was about as much as a replacement system, so I decided to get a identical 2012 instead. I’m not happy about why I had to buy it, but my hard drive is fine so I can make it like nothing ever happened by swapping the drive over.
Anyway, everything else about it is fine outside of the screen and board - including my hard drive so I still have plenty of reusable parts to pick at. I can drop the old hard drive into my new machine and be back where I am, but my replacement shipped with Sierra AND I updated to High Sierra (no APFS). To make it so I can run it for data recovery, I put Kapton tape over the LVDS connector and LVDS cable so I don’t have to worry about the short. Since my replacement is not on High Sierra, I don’t know what kind of updates I need to run to get the EFI firmware current or if it’s even an issue at all.
Once I install High Sierra and check the EFI is current, is it still possible to switch hard drives between systems with very similar hardware? I know it worked in the past but the EFI updates changed things dramatically.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Hope I understood you corectly
A Macbook Pro 2012 with a High Sierra install can run a lower MacOS hard drive but a Macbook Pro 2011 cannot see a High Sierra formated (APFS) drive
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
What I want to do is remove the drive from the 2011, update the new one to High Sierra WITHOUT APFS (Not ideal for spinning rust) for EFI insurance and just have a newer machine. I'll take on the APFS upgrade when I get an SSD.
door
@nick yes you can take the old drive and do the update
door
Voeg je antwoord toe
Nick zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 95
