Ga door naar hoofdinhoud
De zevende iteratie van de iPod Touch van Apple, uitgebracht in mei 2019. Dit model wordt geleverd met maximaal 256 GB opslag en een A10-processor. Modelnummer A2178.
How to fix a dropped iPod?
I dropped my Ipod on the ground about an hour ago and it is just the glitchy screen with the lines. How do I fix this techy people? <SOS>
Update: I let it die and then plugged it in and left it alone for a couple hours and it seems to be working fine now. There is still some slight screen flashing but it’s almost unnoticeable.
Is dit een goede vraag?
Score 2
7 opmerkingen
Is the screen flickering still happening?
door
slightly, yes
door
Its possible you loosened the connection on your motherboard. There's no cracks or anything on the screen?
door
Awesome glad to hear! It was totally the big UwU energy that fixed it.
door
okay you have to be one of my favorite people in the entire world
door
2 commentaren meer tonen
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
it seemed to have fixed itself, thanks for trying though, it means a lot to me. :>
Was dit antwoord nuttig?
thank you i would cry if it is broke
1 Opmerking:
Thank you SO MUCH for this solution. My iPod was flickering after I dropped it, no matter what I tried. But I turned it off (powered off) and let it rest a few hours and the flickering was fixed. I’m so grateful 🙏🏻 . (Note: one hour was not long enough, was still flickering)
door
My iPod drop and it won’t come on
1 Opmerking:
If you scroll up you’ll see that others have said they let it die and then plugged it in and left it alone for a couple of hours and then turn it on again, this fixed the problem. Their suggestions worked for me. Good luck.
door
it happens with all 7th gens i wanna believe, when you drop it it kinda like makes the phone panic and renderitself useless like some sad lil puppy on the side of the road. just hold the power,volume, and home button down which resets it and when it powers back on it may flicker but thats only because the LCDs were a bit burned for a bit but will ultimately go back to its normal state within a few hours. it depends on how long the phone was in that state. the longer the phone has the lines the longer the flickering and the lines will appear on the screen. I dont know what causes this but if anyone knows please tell me. im very curious
Voeg je antwoord toe
UwU_Person zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 42
Altijd: 6,057
