Ga door naar hoofdinhoud
The second generation PlayStation Vita, the PCH-2000 series, is commonly referred to as either the PS Vita Slim or the PS Vita 2000. Announced in Japan fall 2013, and released in North America in May 2014. It is rated as a hand held entertainment device. Supported by :: Wi‑Fi, PlayStation Now, PlayStation Network / Plus, Bluetooth. Model number: PCH-2001.
Spilled hot chocolate on it, now it won't charge w/ no charging light.
I’ve replaced the battery and cleaned up any visible gunk on the motherboard, but it won’t even give me the orange light when I charge it. I’ve got a soldering iron if I need to use it, but I’d really rather avoid having to buy a new motherboard. At that point I may as well just buy a new Vita.
I’ve attached photos of the motherboard, any suggestions would be very much appreciated.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi @parlock ,
Did you remove the shields covering some of the components and clean under them as well, you didn't say?
If you didn't remove the shields do not connect power to the board again until it has been fully cleaned and inspected.
What did you use to clean the board, hopefully Isopropyl Alcohol?
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Yep, cleaning-grade isopropyl alcohol.
I didn't know you could remove the shielding, how do I go about that?
Thanks!
door
Hi @parlock ,
It can vary how to do this.
Here's a link that shows one way that the shields can be removed. Don't apply too much heat for too long ;-)
Other shields may have lugs that are directly soldered onto the board or clipped on maybe. Bit hard to see from the images that you posted how yours are attached
door
Voeg je antwoord toe
Parlock zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 84
