Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
466 Vragen Bekijk alle
How to setup the ps3 without the original controller
I bought a ps3
and he came without any accessory and i have a Genesis controller and i cant do the setup with this controller but on the box says compatible with ps3.
I need a original controller or what?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
4 Antwoorden
Gekozen oplossing
Power A controllers can easily accept different drivers for different systems. Download the controller driver from your game consoles website, to your computer. Connect your Power A controller to your PC via USB. On Windows go to control panel, devices and printers. Click on Power A. And install driver…. Done.
Enjoy.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
If your controller came with a USB cable, connect it and press the PS button. If it did not, you will have to buy one. If you already have a USB cable and it still does not work, you may have to buy a controller made by Sony.
Score 1
5 opmerkingen:
You're welcome, if this helped.
door
Thank You so i need to buy a new controller??
door
If your controller does not register even with a USB cable that connects on both ends correctly, then you may have to buy a PS3 controller from somewhere, as I do not know how to get it to work otherwise. If someone else has another answer, theirs may be better. Then again, I'm not quite an adult yet, either.
door
Ok Thank You Very Much!!
door
I worked for SEA tech support, basicly helped customers remotely repair there systems over the phone...there is no way to use the safemode or restart boot menu without the official duleshock 3..no aftermarket controllers will work unless your at the homescreen and even some games have issues with the aftermarket
door
What if I don't have original controller I have a (power a remote ) but it says connect controller to USB and press is button what I do?
1 Opmerking:
It says connect controller with cable. I bought this with cordless how do I reset to play?
door
I have team5 usb controler, and my sony does not recognize it? What shoud i do?
Voeg je antwoord toe
NT GAMER1 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 20
Afgelopen 30 dagen: 72
Altijd: 13,783
