Ga door naar hoofdinhoud
The Black and Decker Dustbuster CHV1410 is a cordless hand vacuum used for light household cleaning. It is also a member of the CHV model series.
3 Vragen Bekijk alle
What can I do to stop my vacuum from turning off every 10 seconds?
The vacuum worked fine the first few times I used it, but it now turns off every couple seconds even when the battery level says it has charge.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
The battery cells have died. You need to replace the overpriced battery. It won't be covered under the warranty. :/
Was dit antwoord nuttig?
Score 2
I think it’s the switch. Mine is having the same problem, but the batteries are fine. When I took apart and engaged the switch manually, it worked with no problems.
I replaced the batteries but it didn't help it still slowed down and stopped in about 20-30 seconds. I'll update this post if I find a fix.
Voeg je antwoord toe
Alyssa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 42
Altijd: 2,178
