Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1200 Vragen Bekijk alle
Doing A Glass Only iPhone X Repair At Home
Hey so my iPhone x has a cracked screen, the amoled screen works completely fine with 3D touch and everything working, its only the glass that’s shattered, i looked to do a screen repair but i realised screens where quite expensive and the cheap ones looked bad quality, also i want to keep features like true tone ( i know there are machines to program new screens to use true tone but again that;s costly) I’m now looking to do a glass only repair at home, I’ve watched a few videos but all of them seem to use big machines like vacuums and other machines to laminate the screen after the glass is removed, i wanted to ask if there was any other way to do a glass only repair at home without any machines.
thanks alot
ismail
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
If you want to do a glass-only screen job for cheap, don’t do it. Buying all the tools will only cost you more than a screen, and you will almost certainly ruin the first few tries.
Do screen-only repair only as a business, NOT DIY.
Was dit antwoord nuttig?
Score 2
Sadly, If you want a premium finish on the job, you’ll have to use the method described in the videos with the big machines.
Replacing a screen is a job that needs fine hands. I suggest you weigh the available options carefully before you dive into one.
Judy Smith.
Score 1
2 opmerkingen:
My dad is a neurosurgeon so I’m not too worried about the fine hands part but is there no other way to do it without machines?
door
It is difficult to be able to do a job without the tools for that job. Ask your father for money and avoid breaking screens by making such a risky repair without knowledge.
door
Voeg je antwoord toe
ismail soleiman zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 189
