Ga door naar hoofdinhoud
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
How to determine if iPad homebutton is original?
So i am replacing the digitiser for a customer, but while testing i noticed that touch id couldn’t be activated. so i was wondering if there is a way to determine if the homebutton in the customers’ ipad have been replaced before, causing touchid to malfunction?
thr only thing i see on the home flex is the text: 821-01017-A MFC4017. on the rear side of the silver “box?” of the home flex, there is a qr code, and the text:
821-01
006-A
A E I (The ‘E’ is vertically mirrored)
I don’t see any apple logo, but i don’t think it is protocol on this cable? there is a foam square stuck to the bracket, which i am pretty sure wouldn’t be the case on an unoriginal cable.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
In 3uTools, there is an option on the main screen called “View Verification Report”. It will tell you if the home button is not an original.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Tubbe Lenbroch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 155
