Ga door naar hoofdinhoud
Released June 2005, identified by model number AL1916.
When switching to second screen it says out of range
I have a laptop and a monitor. It works fine when putting it on laptop only, Duplicate and expand but when i put it on Second screen only it says: Monitor out of range or something.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is caused by the screen resolution setting being not matched up the second monitor. When you are in duplicate or extend mode, lower the screen resolution on second monitor and try it again. You can also change the screen resolution using the monitor on-screen menu controls to fix this issue. Check the buttons on the monitor for those controls.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
FLYNC zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 243
