Ga door naar hoofdinhoud
Tweede generatie iPhone. Model A1241 / 8 of 16 GB opslagcapaciteit / zwarte of witte plastic achterkant. Reparatie is eenvoudiger dan bij de eerste iPhone. Vereist schroevendraaiers, wriktools en zuignappen.
horizontal 'lines' on screen, after a slight 'knock' to back
Hi, I recently managed to knock my phone against a low post in the street. I knocked the back of the phone whilst it was in my pocket.
I've now noticed that there 'lines' at the bottom of the screen - I assume this is possibly due to a dodgy connection to the LCD matrix?
1. Do you think it's fixable [no other visible 'damage' to the screen?
2. or is it possible damage to the logic board?
The 'lines' are on every screen and have the same colour - dark blue? They are even getting longer, though I don't use the phone now?
Thanks in advance for any help - compassion ;^)
Is dit een goede vraag?
Score 8
10 opmerkingen
The bottom of my screen has grey horizontal lines which stay still. However I have dark blue lines on the top of them, which is duplicating the image behind it, and also moving
door
Black horizontal lines are spread all across my phone screen why?
door
Thin black horizontal lines which on my screen is it permanent or we can solvents it
door
Mine has light blue vertical lines that click stuff when they want to and it gets annoying
door
I too get a black line at the bottom of my tablet what should l do ???? Will it remain like that?
door
5 commentaren meer tonen
Voeg een opmerking toe
8 Antwoorden
Gekozen oplossing
This could be caused by two things.
One - LCD connection has come loose.
This is the simple and free cause as all you have to do is take the digitiser (screen) off and re-seat the LCD connection. If this fixes the issue i would highly recommend buying some Anti-Static Kapton tape. This tape is high quality electrical tape with strong adhesive and heat tolerance.
Polyimide Tape
Two - The LCD has been damaged
This is the harder and more expensive cause as the LCD has been damaged. As per the name LCD (Liquid Crystal Display) if it is knocked or bumped hard enough it causes the "liquid" to displace itself possibly causing those horizontal lines you now see. However all you will need to do is replace the LCD and you will be good to go.
Here is a link to the part you will need to buy
Here is a link to the guide you will need to replace it if you do not know how.
Hope this helps :D
Replace the LCD in an iPhone 3G and fix a malfunctioning display. The display is only the internal LCD panel. The front glass digitizer touch screen and the metal backing plate are not included. Afbeelding
Product
iPhone 3G Display
$29.99
108 foot rolls of Polyimide tape. Perfect match with OEM Apple Part# 922-1731 tape. Half-inch (.5") width. Afbeelding
Product
Polyimide Tape
$9.95
Was dit antwoord nuttig?
Score 5
5 opmerkingen:
I have a iPhone5s and it has black lines at the bottom and my screen won't work. What could be wrong? Could it be bcz I dropped it or banged it on something
door
hi,
my Iphone 8 fell yesterday and the protector screen broke, however it has no damage on the actual screen.
but there is two vertical lines underneath the screen now and the touch screen is not working over those two lines.
do i need to replace the whole screen or how do i fix it?
door
I have iphone 7plus got a single yellow vertical line touch is working
door
mine has horizontal lines on the screen. how much does it cost to fix it if i take it in to a repair shop?
door
Hi I just put my phone on my desk and the next morning I find it with black lines and I can’t do anything I’m scared pls help my mom will kill me and do I lose my tik tok account to
door
I had the same issue on an iPhone 4S and I fixed it by warming it up to body temperature for 30 minutes or so. The lines gradually disappeared!
Score 5
11 opmerkingen:
my phone has also horizontal lines at the bottom... is it really working by warming? many thanks!
door
surprisingly useful!! thank you!!!
door
how did you warm the phone
door
I held it between my legs :)
door
So, you didn't have to replace the screen? My iPhone 5s has the same issue and I don't know what to do. I would appreciate any advice
door
6 commentaren meer tonen
help me there is a small blakcl ine on the right screen on my iphone 6 :(
Score 2
1 Opmerking:
Same to me though...
door
Hmm.. It depends on the lines. If they're black, it's usually the lcd. If white, then it's an issue with the digitizer. Yes, it can be repaired. If their white, you can try reconnecting the display cables, and cycling the battery. If black, you can easily replace the lcd, on that phone
4 opmerkingen:
It was a very helpful tip n I found the problem is with digitizer. Now the phone is working fine. Thanks
door
My lines are purple And i found them only in my camera please tell me what should i do?
door
What about purple all over, it comes back and leaves
door
mine was a series of green red black lines going downward then just quit
door
i need help. Currently my phone is black(bottom part of it) and the top part is mixed with purple dots and i cant fix it.I tried a the power method and such but i still couldnt make it work. Please help. (Samsung note 4)
3 opmerkingen:
You need a new display assembly,-/. Your lcd is damaged
Galaxy Note 4 Screen
Samsung Galaxy Note 4 schermmodule vervangen
door
My iphone5s some unresponsive touch .it cause a black thin horizontal lines on bottom.it increase while using brightness.what is the problem how to fix ?any body give idea please
door
My iphone 8plus has verticle lines and screen seems a bit deem then it used to be. Text also reflecting back on screen like copying of it. Not damaged or fall on ground for sure. Please advise. Does apple cover if its under warranty to fix it?
door
I have a Samsung 8+, just recently, I noticed a black horizontal line on front camera ( unable to do selfies ) what can I do ?
i have iphone6 which displays on and off showing several horizntal lines….what exactly issue is?
If these will be any physical damage then it can't be fixed. Replacement is the only option to solve this problem. If it happens because of any software issue then update your smartphone this may solve your problem. Either there is a another solution older saver some users clam that they have solved their problem through it.
This may bring life to your dead, stuck pixel of your display. Better give it a try.
Voeg je antwoord toe
binaryop8 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 242
Altijd: 409,648
