WiFi and Bluetooth card upgrade
Is it possible to upgrade the WiFi an Bluetooth card on a Mid 2012 MacBook Pro 13”?
If so which cards will work?
Is dit een goede vraag?
Sadly, your systems version of board doesn’t offer a newer board. BroadCom made this version of board with a surface connector
Unlike the newer Retina series (pre 2016) which uses an edge connector
While the latter versions of retina models offered a better WiFi/BT board you can’t use it.
So your system is stuck with the AirPort Extreme it came with: WiFi - 802.11n & Bluetooth - 4.0 internally.
Now lets look at your options! You do have a Gigabit Ethernet interface and you also have USB3 both offer powerful connection possibilities. Most people really don’t need on the road speed, its when working at a desk that we often need the higher throughput for accessing a NAS or File Server for files or backup.
Was dit antwoord nuttig?
Go to system information and check for WiFi section and you can find your model and replace with it.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 376
