Ga door naar hoofdinhoud
A1708/EMC 3164 — Released June 2017, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar).
563 Vragen Bekijk alle
Dark Horizontal lines on MacBook Pro 2017
I have a MacBook Pro 2017 non-touchbar.
My screen is having a horizontal lines in the bottom till the middle of the screen as it shown in the picture
When I let my MacBook Pro runs for more than 4 hours the lines start to appear and within the time the lines get darker.
When I shut down the computer and turn it on immediately the lines get less darker and if I shut it down for some time the lines disappear.
What is the reason for this problem because I’m not even running a heavy application and it’s not overheating according to the numbers but somehow my fan constantly runs on 1200rpm
It’s really frustrated that I spend above 1500$ and I keep getting this problems. First problem was my trackpad haptic feedback didn’t work for some time for no reason and now it works by itself
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
1 Antwoord
I would check if that Fan Control software did not hijack the control of the fan, then perhaps will try to use another fan control software. since the readings for all sensors looks normal it will most probably solve conundrum with those 1200 rpm.
As for those lines - most probably the case of that famous here "delamination issue" of the T-CON board, though, are you sure your Macbook haven't been in the warm and humid place before? I mean even if you have to go to Apple with this problem to replace the display assembly, I would still suggest checking the water indicators inside your Macbook first.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ahmed Barahim zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 3
Altijd: 266
