Ga door naar hoofdinhoud
The Toyota Corolla's eleventh generation was released in May 2012. In Japan, the sedan is called the Corolla Axio while the wagon variant is named the Corolla Fielder.
19 Vragen Bekijk alle
How to fix small scratch in my car?
Toyota corolla le black 2018
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
if the scratch has just gone through the clear coat and looks like a small white one then a touch up pen with clear lacquer and a good buff up when its dried will sort it out. if its gone down to primer or even metal you’ll need paint that's colour coded to the car, either in a touch up pen or spray can, and cover the mark then same process as above. if its large enough that you don’t think it will be covered then get the panel re-sprayed.
Was dit antwoord nuttig?
Voeg je antwoord toe
Bob Vv zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 17
Altijd: 542
