Ga door naar hoofdinhoud
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 Vragen Bekijk alle
What effect does resetting the PRAM have?
On several sites there are instructions for resetting the PRAM in the computer. However, I've not been able to find out why one would want to do this in the first place (except as a general "if you are having problems, try resetting the PRAM"), nor if there would be any potential negative consequences, such as the system failing to recognize the hard drive (ouch!) or other issues.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
PRAM contains many system settings including the volume, some display settings, the time zone, etc...
see this article from Apple for the full details
http://support.apple.com/kb/ht1242
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Ricard Wanderlof zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 8,104
