Ga door naar hoofdinhoud
The second-generation (Mk 2) Ford Focus was launched in 2004 as a three- and five-door hatchback and an estate variant.
37 Vragen Bekijk alle
Ford Focus Electrics Dont Turn Off
Hi
I have a Ford Focus 2010 plate. When I turn off the ignition the CPU on the dash stays on, which in turn drains the battery. Any suggestions? I have already changed the battery once.
Thank you
Duncan
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
is it constantly staying of for hours or just for a couple of minutes after the car is locked? they usually stay lit for up to a couple of minutes after the car is locked and the ecu itself up to half an hour then go out, other power sources in the car will stay on after the ignition is off, nothing plugged into them is there like a dash cam or anything?
Was dit antwoord nuttig?
Voeg je antwoord toe
donuts83 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 12
Altijd: 300
