Ga door naar hoofdinhoud
The TI-83 Plus is a graphing calculator released in 1999 as an upgrade to the TI-83.
39 Vragen Bekijk alle
Where can I get a replacement for my IO port
Someone tried to jam an ordinary headphone jack in there and ended up splitting the entire jack into pieces, i am unable to connect with the cable i just bought (and was hoping that it might still work but wasn’t expecting much). Where can i buy a new part for it? I can do the soldering myself but just need a new part.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
You can find replacement parts on places like Digikey, Aliexpress, and likely even Adafruit or Sparkfun. You’ll have to find a port with the correct footprint of course. If your port is too mutilated to tell, here’s some photos I referred from: top down view and close up. You’ll want a port that is 2.5mm and has 3 conductors and 3 contacts.
I don’t have the dimensions of the original port, however with some quick research, I found this port which looks like it should fit. The only issue is the back contact doesn’t line up with the contacts on the PCB. You can likely just solder a wire from the contact to the PCB however, if you look at some of the sites I provided above then you may be able to find a more suited part.
Was dit antwoord nuttig?
I was unable to find a replacement, so I took an orthodox approach; I soldered female pin headers to each of the 3 solder pads that the IO port would normally be soldered to and snipped off the end of my link cable, and soldered a male pin header to each of the 3 wires from the link cable.
While this method was a bit hackish and certainly not the prettiest thing in the world, I am now able to connect my ti 83 plus to my computer by simply connecting the 3 female connectors to their corresponding male counterparts.
EDIT: I eventually got the courage to give my calculator the repair it deserved. No more ugly wires coming out of the calculator!
Voeg je antwoord toe
The Awesomer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 93
