Ga door naar hoofdinhoud
Lenovo N23 Chromebook by Google Chrome
7 Vragen Bekijk alle
Broken LCD on Lenovo N23
Hello!
My N23 chromebook is cracked, so I have two questions:
1-somebody can show me where I could buy a new LCD screen? Just to avoid buying the wrong one.
2 - I have some experience in replacing LCD´s, but does somebody have experience precise with this model? It would be way faster with a guide :)
Thank you so much!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
(Remove cover and Disconnect Battery) Remove the front LCD Plastic Cover, Remove 4 LCD Screws and Install a new one. You can buy any LCD Screen with this specs from mayor sellers.
Lenovo N23 CHROMEBOOK SERIES
size: 11.6" WideScreen info
resolution: HD (1366x768) info
Surface Type: Matte info
Video Connector: 30 pin video connector info
Mountings: Side Brackets info
ORRRR if you want to be 100% SURE that screen will work, remove the broken LCD Screen and buy it by model Number LTXXXXXX something.
Was dit antwoord nuttig?
Score 1
Luckily I work with these laptops everyday and the screens are pretty much the same between all 11” chromebooks from what we have experinced. All you need to do is remove the 4 hidden screws on the display bezel and then remove that. (it does take some force but be sure not to break it) Then there will be 4 screws around the screen remove those but don’t yank the screen out there is a ribbon cable then cut the tape on there and lift the little hinged connector and remove it then replace the screen and redo all the steps.
Score 1
Voeg je antwoord toe
Andrea Valentini zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 7
Altijd: 230
