Ga door naar hoofdinhoud
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
327 Vragen Bekijk alle
No power on when opening the lid / no sleep mode after closing the lid
Hi there,
My 2017 15” Macbook Pro had a slight water damage which was fixed. But I realized now that when I open the lid, the Mac won’t start. The sleeping mode doesn’t also work when closing the lid.
Does anyone a solution for this? I already tried to replace the trackpad – no fix. Changes in Terminal did not help to solve the problem as well.
Thanks in advance!
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Well I’ve got some bad news here the Touchpad doesn’t have any involvement in sensing the lid. The main logic board has the sensors as you can see here:
These are located on the back side of the logic board (you can’t see them without removing the logic board)
Most likely your logic board still has liquid damage. At this point you’ll need a new one.
Was dit antwoord nuttig?
Voeg je antwoord toe
albert einstein zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 99
