Ga door naar hoofdinhoud
Uitgekomen op 4 november 2017. Model A1865, A1901. Verkrijgbaar als GSM of CDMA / 64 of 256 GB / Zilver of Space Gray. (Uitgesproken als "iPhone 10".)
1199 Vragen Bekijk alle
Blurred camera after replacing back glass
Hello everyone,
Probably not done the best repair work of my life here, and I know there are other methods of changing the iphone X back glass, but I used the “Heat-gun” method
Having a severely cracked back glass, Using a hot air gun to remove the adhesive I was able to remove all of the glass and remaining fragments WITHOUT touching or moving the camera lens cover…. the issue now that trying the camera app (or any that use the rear camera) it seems to focus in a blurred manner.
My question here would be…. what is the most likely cause? I would assume the camera assembly may have overheated and now caused the blurr ?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Yes, you have fried the rear camera. it should be removed as very sensitive to heat.
Was dit antwoord nuttig?
I have this problem too, so how you solve that? Change the new camera?? :((
Voeg je antwoord toe
kristian zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 1,936
