Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
iPhone 6 Won't Charge. Replaced Battery.
I recently started getting into phone repair as a small hobby. I got an iPhone 6 from a friend that will not charge. I replaced the battery and it booted up just fine. When I plug it in, it turns on but does not charge. Did a hard reset and the charge port seems to be clean. What is my next step in repair? Should I replace the charge port? It will not connect via the charger.
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
You need to rule out parts first. Try another dock and if it still will not charge you will have to replace the Tristar IC.
 If you are getting into IPhone repair this is the most common problem you will encounter. Check out some YouTube videos so know what equipment you will require.
Was dit antwoord nuttig?
Score 2
That is your dock connector (Lightning port) if this does not fix the issue it will be a board level repair which most likely can include micro soldering. Good Luck!
Score 1
Voeg je antwoord toe
Chandler Bohnen zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 2
Altijd: 46
