Ga door naar hoofdinhoud
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
239 Vragen Bekijk alle
Will not power up
This one was working fine. It was shut down and in the morning I got nothing.
I disconnect the mag-safe adapter, disconnect the battery from the logic board. Press and hold the power button for 10 seconds. Now plug the battery back in then the mag-safe and did not get a spontaneous reboot. The keyboard lights occasionally, but no post tone. It will shut down the keyboard lights when I press the the location of the normal start. The fans do not come on. @danj any ideas? This machine has not been worked on by anyone else, I did the initial system installation and data migration in late 2016. It has had no problems till now. I’m pretty sure it would also have Symantec anti-virus on it. I left it plugged in overnight, so I assume the battery is charged.
Is dit een goede vraag?
Score 1
7 opmerkingen
@mayer - MagSafe?? This series uses a USB-C power adapter.
door
@danj of course it uses a USB-C. But it's not a mag-safe or I could see if it was charging, but I can't. Thanks for improvement Apple.
door
@mayer - Just making sure we're betting on the right horse here ;-}
When you open the lid do you see the battery icon when you have the power adapter plugged in?
You may want to get a USB-C power meter as I find the display fails to show up when I would have expected it to. Satechi USB-C Power Meter Tester. I wish Apple had given us a simple charging LED.
door
@danj I see nothing when I open it. It was only when I did the battery disconnect and reconnect that the keyboard lite up. Yes, I bought a power meter tester several months ago when you recommended one. I will give it a shot in the morning.
door
@mayer - Any news?
door
2 commentaren meer tonen
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sent into Apple. A tier 2 repair.
Flat Rate 2 Repair Charge MB/MBAIR/MBP13 $405.94
Labor Charge, IB/MB/MBAIR $108.25
PORTABLE SHIPPING CHG $21.60
Total in USD $535.79
Plus tax
UPDATE 1/16/20
Apple ending up replacing the logic board, and the display and the bottom case.
So just in parts costs, the Flat Rate Repair was really worth it.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
@mayer - Happy you got it fixed! Hopefully you didn't spend too much on the system to start with.
door
@danj just sent it in yesterday, it is a customers machine.
door
Kevin If they quote you a Flat Rate Fee, that's it, no charge for any parts.
door
Voeg je antwoord toe
mayer zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 3
Altijd: 446
