Ga door naar hoofdinhoud
Larger version of the Nintendo DSi, released March 2010 in North America. Most repairs are accomplished with only a screwdriver and prying tools.
will not read games
I'm having a problem with my DSI XL. It will not read any games. I've cleaned the games, I've also did a system update. It still won't read any games. I don't know what do anymore. I'm afraid its broken but I just wanted to get another opinion. thanks
Is dit een goede vraag?
1 Opmerking
I am having the same problem!
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
either:
1) the pins that make contact with the game are bent/broken/dirty. look into the reader with a flashlight and see if anything's going on. rubbing alcohol + small brush will take care of dirt. tweezers can take care of a bend. broken pins will require a new reader to be soldered in
2) bad solder joint between the reader and the main PCB. Reflowing is a pretty easy job if you have the tools, a replacement is a little more complicated.
good luck
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Camille zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 1,905
