Ga door naar hoofdinhoud
Aftermarket power adapter advice
I lost my original charger on a trip so I need to get a new one. Found a brand called Topnma making a non-branded but identical charger with same wattage and volts/amps rating. Can I trust it?
Is dit een goede vraag?
1 Opmerking
If you can wait to buy a proper charger I would hold off buying that. There's always a risk of the charger going bad and killing the laptop.
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Hi Goodman 4525
In general it should works, but it might not be properly designed like the original, e.g. short circuit protection, safety features, etc.
I know some cheap adapters, either that, output voltages can be “dirty” alot of noises, which is no good for your laptop.
cheap adapters normally efficiency and safety are always a concern.
perhaps you can save some money, but no one knows on the long run if it can harm your computer.
Was dit antwoord nuttig?
Score 3
Voeg je antwoord toe
Goodman 4525 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 74
