Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Vragen Bekijk alle
Not charging after battery replacement
I recently replaced my battery with one I bought from ifixit. It worked fine for a few weeks but suddenly it stopped charging. When I connect the charger it indicates that it charges but the battery does not charge at all. I opened the phone, disconnected and reconnected the battery and it seemed to be OK for the next weeks. Since yesterday I have the same problem again and the same trick did not do anything at all. Any ideas?
Update (11/23/2019)
Thank you all for your help. An update: I checked the charger port flex cable which seems fine. Then I disconnected the battery and when I plug the charger the phone shows the apple logo. The battery cable also seems to be OK. Maybe the battery itself is faulty? Should I ask for a replacement battery?
Is dit een goede vraag?
4 opmerkingen:
I have tried different cables with no luck. The port and flex cable also seem intact.
door
Does the battery look swollen?
You could have gotten a faulty battery.
door
Nope. The battery seems fine. Should I try connecting it without the battery? Just to see if the logo comes up? Or maybe the battery is faulty without being swollen? @Matt Black
door
When you put it on the charger, does it show anything on the screen? Can you power it on? Does the screen just stay black?
door
Voeg een opmerking toe
3 Antwoorden
Make sure lighting cable is not damage.
Check the lightning port for dust and check to make sure the flex cable is not damaged or bent.
Check battery cable is not damaged.
Was dit antwoord nuttig?
check the charger port flex cable , it maybe not connect properly . beside the battery connector
Try to get a replacement
1 Opmerking:
I just tried another battery and the problem remains the same. So the battery is fine. Do you think the phone can be repaired?
door
Voeg je antwoord toe
Johnny Parcharidis zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 117
