Ga door naar hoofdinhoud
Apple's fourth-generation smartwatch, with optional cellular connectivity, released September 21, 2018.
124 Vragen Bekijk alle
What is the role of this part?
My watch’s glass was broken and I repaired(replaced) at personal fix store few months ago.
Today I found a gap between the glass and aluminium frame.
He was not a good engineer -_-;
I teared it and saw the flat cable(?) was cut ; the red line of the image.
Questions.
1. What is the role of the part that blue lined? Is there any disabled work by that disconnection?
2.Can I replace it? I couldn’t find that part by googling.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The part is a foil shield to protect the display/touch assembly from EMI noise from the battery/SIP module blow it. Here’s a better view
The cut off segments (right side) are the connection point to the case (drain). Apple does not offer replacement parts.
As this point I don’t know if your watch is repairable or not. I hope you got your money back from this person as he clearly didn’t know what they where doing!
Shields are important! Maybe you can find a junker watch which you can salvage the shield from.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
thank you so much
my curiosity was answered
one more question.
can the disconnection make influence to blutooth?
AIRPod works only very close to the watch after repair.
door
Sadly yes! The EMI noise can interfere with the wireless connections (Bluetooth or WiFi)
door
thank you very much
i’ll try to make an alternative means
door
Voeg je antwoord toe
DJ KIM zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 2
Altijd: 90
