phone sound stopped working after battery replacement
Not sure what happened. Installed a new battery with no issues however no sound is heard while making calls. Speaker works just fine.
Is dit een goede vraag?
· Did you remove the screen while replacing the battery?
· If you record a voice memo can you hear it through the ear piece speaker?
· Is your front camera working correctly?
If you could here on calls before you replaced the battery and you removed the screen while doing so it would point to the front camera flex assembly. Check if the connector is seated properly into the connector.
Was dit antwoord nuttig?
No to answer your first question.
However I started over and did remove removing the battery before removing the screen.
The ear speaker was working again BUT front & rear camera did not work.
One step forward two back it seems.
Started over this morning. Now no ear speaker or camera (front or back)
Should I just replace front camera and censor cable?
Yes. That should fix the problem. They are not that expensive.
The first answer is yes and the other two are no it is not even showing anything when I press the volume buttons and the audio and speakers don’t work even on a cal when I try to press the speaker button it is grey or inpressable
So I am confused what should I do
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 1,530
2 opmerkingen
Did you tear the ribbon putting out the battery adhesive
door Noah Byrum
Not sure what you mean "tear the ribbon" what ribbon and where is it?
door allthingsjazz
