Ga door naar hoofdinhoud
Troubleshooting, device, and repair guides for the 2016 Samsung Galaxy J7, model number J710.
66 Vragen Bekijk alle
Is there a possibility for a charger port to burn?
(So actually my phone is J7 Duo, but its just isn’t there.)
Is there a possibility for a charger port to get toasted when the socket i’m using kind of exploded, or sparked?
I’ve tried different wires already, but my phone just won’t charge, and i’m kinda losing hope because when I used those wires on a different phone, it works. (So i’m kinda bummed and sad)
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Yes It is, is one of the common problems on the Smartphone-Repair World, can be broken or a fuse is burn, in this particular model if the charging port is bad or broken you will need micro soldering skills for replacing Charging Port because it is attached to the Logic Board / Motherboard.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Elyxha Denisse zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 18
Altijd: 157
