Ga door naar hoofdinhoud
Wifi Grayed Out When Getting Hot
Hi,
When i charge my phone or use snapchat and the phone get hot it reboots and the wifi is grayed without a mac adress. But when i hit the back with medium force and reset it it works.
I changed the ic but the problem remains the same.
So please if anyone knows what the problem is I’ll be happy to hear it.
Thank you.
Is dit een goede vraag?
3 opmerkingen
What part of the phone is getting hot?
door
@imicrosoldering sorry i don’t know exactly
door
I figured out that i have also issues with the audio ic. So I want to know if the wifi/bt ic and the audio ic are somehow related ?
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
I haven’t encountered this personally but I have heard of others that have. I would defiantly do the audio IC. There is a trace that sometimes goes bad between D12 to G12 that is the 1V8 SDram line, for a problem like this I would defiantly run a jumper between them as well as the other jumpers.
Was dit antwoord nuttig?
Score 2
You have to unbind the WI-FI address from Nand. If you changed the new WI-FI module.
1 Opmerking:
Thank you It’s not me i gave it to an expert who told me that it didn’t work.
door
Voeg je antwoord toe
Walid Dahou zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 64
