Ga door naar hoofdinhoud
The Xbox One S, designed by Microsoft Corporation, was released on August 2016. The Xbox One S is a redesign of the Xbox One.
428 Vragen Bekijk alle
Unable to reformat a 1TB HDD but I can reformat other sizes.
Hey there! For the past month or so, I have not been able to upgrade any XBOX One S with a 1TB HDD. I keep getting the E100 error when applying the final update. It’s only the One S, and only the 1 TB HDD size.
I’ve been using the Andrew Paul method (popular on YouTube) for years with no troublel whatsoever, but with the October update of the OSU1, no 1 TB for me! 500Gb, ok, even a 640Gb is ok. It’s not the brand, tried Toshiba and Seagate drives.
Any ideas? Thanks in advance!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Turns out it is a brand issue. Installed a WD Blue 1TB HDD and all worked perfectly. Which means that NOT ALL HDD brands work. SO be careful when you buy the replacement.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
LAR zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 6
Altijd: 93
