Ga door naar hoofdinhoud
model number A1763
59 Vragen Bekijk alle
Charged, Connects the Disconnects on Contact
My BeatsX will fully charge, and if held in the right position will connect. However, as soon as the wire by the charging port moves, it disconnects from the phone/shuts off. It seems as though there’s a short in the chord. How can I fix this? Do you guys know places near Cincinnati that would work on them? Thanks!
DW
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Sadly, there is little you can do as any surgery will kill the patient!
While you could cut the case off to gain access to the wires to hopefully patch them, you won’t be able to reseal things to the point it will hold up very long.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
David Walker zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 4
Altijd: 45
