Ga door naar hoofdinhoud
Fourth generation of iPad, released November 2, 2012, available in 16, 32, or 64 GB models. Model Number A1458
error 9 , error 40
Hi , i have an ipad 4 which suddenly showed the apple logo during normal use . when i tried to update / restore i got error 9 , i tried a new lightning port , new battery , tried a restore with reiboot pro . also tried another pc and a macbook for the restore …
I removed the board and used naviplus pro to read the nand chip , seems ok , i also repaired the nand with naviplus and tried to restore again , now i get error 40 . , i’m thinking now may be cpu , is there a test to confirm this ?
..here is a link to the itunes restore log
https://www.dropbox.com/s/3al0q9okudom8e...
Is dit een goede vraag?
1 Opmerking:
I,m not sure if i’ve made progress with this or not , i gave the nand chip some heat , plugged it into the naviplus again and noticed the model no R/M . box was blank , i filled this in and it restored ok . now i have activation error !!  ,,  its a wifi only model and i tried the restore with pc and a macbook , same result ,...
door
Voeg een opmerking toe
1 Antwoord
all the way at the bottom of the restore log it says this
[19:07:11.7430] Depth:2 Code:40 Error:storage device did not become available
maybe it is your storage device that is bad, and not a cpu.
Was dit antwoord nuttig?
1 Opmerking:
so that would suggest the nand chip , i thought that as the naviplus machine was able to read and write to it ok that would rule that out ..
door
Voeg je antwoord toe
markparnell1972 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 16
Altijd: 241
