Ga door naar hoofdinhoud
Cellular version of Apple's 2nd generation iPad Air. Model A1567.
86 Vragen Bekijk alle
iPad Air 2 wont turn on
iPad Air 2 wont turn on or charge, there is absolutely no signs of life. i measured it via lightning caple to input voltage about 5.20 volts but not any current, it says 0.00amps even after charging overnight. Tried hard resetting multible times, no luck. iTunes doesn’t recognize it at all.
I really want to see if i can fix the problem without taking it apart, since i dont want to risk cracking the expensive display/digitizer combo.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Maybe you have a bad dock charging connector??
Is the charging cable loose when it is inserted in to the dock
Has you do not want take apart the iPad ?/ bu what you are saying you will have to
The Thristar tester would give you a good idea what is faulty but not 100% full proof
Link
https://www.repairsuniverse.com/products...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
it might just be that the battery is stone dead and needs replacement. the lightning connector fits snug and perfect within the charging port without any wiggle room. i guess i will have to take it apart and start testing.
door
Voeg je antwoord toe
Tubbe Lenbroch zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 76
