Ga door naar hoofdinhoud
The Asus Zenbook UX301LA is an Ultrabook with a 13.3-inch IPS display. It was released in November 2013 as a part of Intel's Ultrabook line.
16 Vragen Bekijk alle
Will a replacement battery for a UX301LA work in a UX533F zenbook?
I can not find any information in the UX533F. The model mentioned in this question looks the closest to the zenbook I am looking for a battery for. Wondering if they have the same battery.
Is dit een goede vraag?
4 opmerkingen:
depends does it fit the port for the battery and is it same voltage and mwh output?
door
Der Anschluß zum Netzteil wurde schon ersetzt.
door
@Ayden Aldrich
door
@Ayden Aldrich The connection to the power supply has already been replaced.
door
Voeg een opmerking toe
1 Antwoord
Hi @waydeph
according the specifications,
UX301LA is having C32N1305 battery, which is not fully compatible with UX533F (voltage and capacity are different). It’s compatible with Zenbook UX301LA Zenbook UX301LA-C4003H Zenbook UX301LA4500. If you want to search for compatible battery, please disassemble your laptop and check manually, what’s written on it. When you will get a PN, you can easily search for the part on the Amazon, etc.
Note:
I’ve only found, that your laptop is compatible with 0B200-03120100, 0B20003120100, C41N1814, C41PPEH batteries. The original battery is supposed to be NASC41PPEH4800B4.
For the better know, check it manually.
Was dit antwoord nuttig?
Voeg je antwoord toe
Wayde Hall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 5
Altijd: 168
