Ga door naar hoofdinhoud
Guides for the LTE version of the iPad Mini 4—model A1550. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
New display didn't come with accessories
I'm replacing the display on an iPad Mini 4. The original one was demolished and the home button was actually missing. I ordered the replacement screen from AliExpress among with a new home button, but neither came with the home button “riser” (thin plastic ring that goes on the glass first). Could I use one from an earlier iPad Mini?
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
That “riser” thing is generic, you can transfer from any iPads. What you also need is a rubber gasket which doesn’t usually come with replacement home button
iPad 5/6/Air 2/mini 4 Home Button Gasket
You can get it cheaper elsewhere, or use salvaged ones with right cut-out
Replace the adhesive gasket that holds the home button face onto the back of the front panel glass compatible with an iPad 5, iPad 6, iPad Air 2, or iPad mini 4. Afbeelding
Product
$1.99
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
I would also add to remember to transfer magnets from the old to the new screen, they might go unnoticed unless one did the job before.
door
@arbaman good point! transfer magnets, sleep/wake sensor, etc. from old screen if new screen doesn't have them pre-installed.
door
Voeg je antwoord toe
Bill Shannon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 50
Altijd: 279
