Ga door naar hoofdinhoud
Reparatiehandleidingen en ondersteuning voor afwasmachines.
707 Vragen Bekijk alle
My LG dishwasher died, how to do CPR?
Good day,
i bought a house a year ago and all appliances came with it including a LG Dishwasher. Few month after moving in, the dishwasher stop working mid cycle, light off, nothing works. I’ve checked the power source and everything is fine but the DW doesn’t light up, no code error, nothing…
I don’t understand electronics but i would like to try fixing it… please help
Update (10/12/2019)
The model number is LDS4821ST
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
First thing to do is check the wall plug for power. Plug something into it you know works and test. There’s not much information here to go on to get any further.
UPDATE
You need to get in there with a multimeter to try to located the break in the power.
Digital Multimeter
Main Control Board
The main control board provides power to nearly every component of the dishwasher. If there is a problem with the main control board, it might not send voltage to the dishwasher, causing the dishwasher not to start. Control boards are often misdiagnosed—make sure you check more commonly defective parts before replacing the main control board.
https://www.repairclinic.com/RepairHelp/...
Digital Multimeter Afbeelding
Product
Digital Multimeter
$19.99
Was dit antwoord nuttig?
Score 1
1 Opmerking:
thank you for answering.
I have verified and there is power going into the DW (hard connection). But nothing work, no lights go on, no sounds.
door
Voeg je antwoord toe
Stephane zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 117
