Ga door naar hoofdinhoud
A washer series by Maytag with a low rate of customer satisfaction and a high rate of failure. These washers have the model numbers MVWB300xxx or MVWX300xxx.
213 Vragen Bekijk alle
My Maytag Bravos XL washer displays ul code and will not finish cycle
Hello,
My Maytag Bravos XL washer displays ul code and will not finish cycle. The washer usually stops around 10 minutes and attempts to even load. Unfortunately, the washer is unable to finish load. I have tried the quick fix and ran diagnostics with no success. I am wondering what to do next. Replace bearing, replace sensor, replace the suspension rods, replace hub….. I’m just wondering where should I go next or if there is a way to narrow down what is exactly wrong with this model washer.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Try this easy fix first:
https://www.youtube.com/watch?v=RNOFc6do...
Was dit antwoord nuttig?
Score 1
1 Opmerking:
That’s the easy fix I tried. Unfortunately, it did not work.
door
Voeg je antwoord toe
Ashlie zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 42
Altijd: 907
