Ga door naar hoofdinhoud
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
216 Vragen Bekijk alle
Speakers not working after repair, MacBook detects earphones in jack
The keyboard on a family member’s Macbook Pro (13”, late 2016, Function Keys) broke. Since it was covered under the repair program, we took it to an Apple Authorized Service Provider (not Apple themselves) so that it could be fixed for free.
The repair took a few days, and we received the Macbook back. The keyboard now behaves normally. Unfortunately, the speakers (which were perfectly fine before the repair) no longer work. In settings, it seems that the Mac is detecting an earphone in the headphone jack, and so the speakers are not emitting any sound. Upon inserting earphones, the sound coming out of them is extremely muffled, and noisy. Even after removing the earphones from the jack, the laptop is still detecting something in the jack, and so does not emit sound through the speakers.
We took the Macbook back to the repair shop on the following weekend. The technician blamed us for the fault, and said that replacing the keyboard had nothing to do with the speakers, so there is no chance he could have done anything to ruin them. He took the laptop in, telling us it was up to his manager whether or not we would be charged for the sound to be repaired. He would contact us when a decision is made, and we could then choose to either proceed with the repair, or take the laptop somewhere else. We await his response right now.
In the meantime I had a couple of questions:
1- Since the entirety of the Macbook’s keyboard was not working, I read that technicians fix the laptop by replacing the whole of the upper case. Does the upper case include the speakers/ earphone jack? Perhaps the technician replaced our upper case with one containing faulty components.
2- If he charges us for the repair, what steps can we take against this individual. If we file a complaint against this repair shop with Apple, what will we be expected to present as evidence for our case?
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Hello!
In your device was replaced the Top Case Assembly with Battery (includes battery, keyboard, trackpad, trackpad cable, audio cable, microphone and audio jack).
Yes, it looks like a problem with audio jack or the logic board (Audio IC is sits there).
So three options here: reseating the audio cable, replacing the topcase or replacing the logic board will resolve the issue.
The only thing i can strongly recommend you is to call to the Apple Support and complain to that Service Provider, be more persistent and don't give up.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Thank you. The shop's manager allowed the repair to progress for free, so there was no problem.
door
@jedaiqum I'm glad to hear that!
door
Try getting the sencers check and if that doesnt help then try using earbuds and or try going blue tooth
Voeg je antwoord toe
Yedai Qum zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 8
Altijd: 1,406
