Ga door naar hoofdinhoud
De Samsung Galaxy S9 kan worden geïdentificeerd aan de hand van het modelnummer: SM-G960XU. Het toestel vormt de negende generatie van de Samsung Galaxy-serie en werd in maart 2018 gelanceerd. Verkrijgbaar in Lilac paars, Midnight zwart en Koraalblauw.
137 Vragen Bekijk alle
Where is the IMEI on the logic board
I sold a phone spares or repair, when the phone left the board was working fine 100% the phone has been returned with the back clearly removed and stuck back on and not working.
Can anyone point me to where the IMEI is printed on the logic board please.
TIA
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
As far as I know, IMEIs are not printed on the logic board, you can find them on the box of your phone (when you purchase it), on the cover for Galaxy S9 and by typing *#06# but in your case this one will not work, the only solution that might help you is to ask the shop where you bought your phone to give you the number, I don’t know if your country can provide you the IMEI but it’s worth trying I guess.
Was dit antwoord nuttig?
2 opmerkingen:
I know the IMEI number of the phone its on the phone and the box the problem is i think a different logic board had been sent back. But as the one which i have recieved back is not working (the one i sent did work) i have no way to check wether it's the original board.
Hence i was hoping the IMEI or serial would be printed on the board or chip somewhere.
door
Manufacturers don't print IMEI on motherboards, you can check this website for more ways to get IMEI number, maybe you find something useful :)
https://www.wikihow.com/Find-the-IMEI-or...
door
Voeg je antwoord toe
Mike Worrall zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 737
