Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
Weak Wifi or poor Signal
This iPhone only sees near WiFi networks. The more far away the router the more poor signal
I have replaced this antenna:
iPhone 6 Plus 5GHz Wi-Fi Antenna
And no differnece
SHould I try with this?
iPhone 6 Plus Wi-Fi/Bluetooth Antenna
Thank you
Update (09/27/2019)
Hi, no antennas have fixed the problem. It seems to be a hardware issue. I will send to my friend’s lab to see if it can be fixed. I will post the results. Thank you
Replace a torn or missing Wi-Fi antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi service. Afbeelding
Product
$23.99
Replace a torn or missing Wi-Fi and Bluetooth Antenna compatible with the iPhone 6 Plus model #A1522, A1524, A1593. Fix unreliable connectivity to Wi-Fi and Bluetooth service. Part #821-00128-A. Afbeelding
Product
$22.99
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
I would like to suggest a cheaper way than replacing a router? But you need jailbreak for this. You can install SignalRefresh Cydia Tweak on your device and boost the signal strength. The tweak is available in Bigboss repository in Cydia apps store. If you feel you need to try this but do not know about jailbreaking will www.cydiacloud.com be useful
Was dit antwoord nuttig?
Score 1
Hi @macpatagon
Have you tried to update or restore the software? Sometimes weird issues can be caused by third party apps and/or software bugs.
Voeg je antwoord toe
Flavio zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 43
Altijd: 205
