Ga door naar hoofdinhoud
Bekijk deze handleidingen voor informatie om je naaimachine te repareren en te demonteren.
20 Vragen Bekijk alle
Bernina 830e service manual (electronic/embroidery/sewing machine)
I need help finding a Bernina 830e service manual. (This is for the electronic/embroidery/sewing machine, not the manual for the 830/831 record that is already listed on this site.) I live waaaaay too far away to get to a dealer for repairs, updates, etc. ''No, my problems/answers are neither found on the Bernina web site nor in the Instruction manual. I have the 250+ page Instruction manual; I need the Service/Repair Manual. Will pay for the correct manual.''
Sorry to scream (above). :-) Just want to save everyone’s time in helping me find the corect manual. For some reason, Bernina has 2 models named 830, which makes it easy to find the incorrect manual. Thanks.
Is dit een goede vraag?
1 Opmerking
Still looking for the Bernina B830 service manual, this is for an 8-series machine. I wish they would update that firmware…hint hint Bernina?
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
If you email Bernina directly and ask them they may be able to help.
https://www.berninamanuals.com don’t appear to have service manuals for the 830 range which is unfortunate. I would suggest contacting them however, as they are probably your best shot: Info@LRBservices.net
I do have a copy of the “Adjustment Manual” which I think applies to all the variants of the 830 model. It may be what you are after, I’m not sure.
Bernina-830-Record-Service-Man.pdf
I hope this helps :)
Was dit antwoord nuttig?
Score 3
1 Opmerking:
One hundred thank you’s!!!!!!!
It is the most helpful thing I’ve seen since I bought the ill behaved 830 12 years ago. You’re great!!!
door
Voeg je antwoord toe
Tee zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 16
Altijd: 999
