Ga door naar hoofdinhoud
An SSD, or Solid State Drive, is a type of storage device that uses NAND-based flash memory to store data.
20 Vragen Bekijk alle
SSD upgrade causes iMac 2015 to freeze after minutes of use
I upgrade my iMac to an SSD and once it boots up after minutes during use it will freeze completely and will not be responsive to anything. I have enabled TRIM settings but find that it is still doing the same thing. What comes next?
Is dit een goede vraag?
1 Opmerking
Can you tell us more details on which model iMac you have as well as the exact SSD you used (make, model and interface SATA or PCI).
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Sorry actually I figured it out apparently I just needed to do a complete wipe of all data and reinstall the OS in recovery mode and now everything is good !
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Jerrell Jones zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 125
